Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Paso 2
Disconnect the backlight cable from the inverter. It is helpful to use a spudger to push the backlight connector away from its socket while you lightly pull its cables away from the inverter.
  • Disconnect the backlight cable from the inverter.
  • It is helpful to use a spudger to push the backlight connector away from its socket while you lightly pull its cables away from the inverter.
Insertar traducción aquí
