Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 8 guías que incluyan este paso.
Inglés
Español
Paso 2
Gently push upward on each side of the power supply control cable connector with the tip of a spudger to gently "walk" it out of its socket. Gently push upward on each side of the power supply control cable connector with the tip of a spudger to gently "walk" it out of its socket.
  • Gently push upward on each side of the power supply control cable connector with the tip of a spudger to gently "walk" it out of its socket.
Con cuidado empuja hacia arriba en cada lado del cable del conector de control de la fuente de energía con la punta de un spudger para que "camine" fuera de su zócalo.
