Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 8 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
The next few steps bring your hands close to the exposed face of the power supply. Do not touch the face of the power supply to avoid a high voltage shock from the many large capacitors attached to the board. Use the tip of a spudger to push each side of the power button cable connector and gently "walk" it out of its socket. Use the tip of a spudger to push each side of the power button cable connector and gently "walk" it out of its socket.
  • The next few steps bring your hands close to the exposed face of the power supply. Do not touch the face of the power supply to avoid a high voltage shock from the many large capacitors attached to the board.
  • Use the tip of a spudger to push each side of the power button cable connector and gently "walk" it out of its socket.
Los pasos siguientes llevan tus manos cerca de la cara expuesta de la fuente de energía. No toques la cara de la fuente de energía para evitar una descarga de alto voltaje de los muchos capacitores de gran carga soldados a la placa.
Usa una punta de un spudger para empujar cada lado del conector del cable del botón de encendido y que lentamente "camine" fuera de su zócalo.
