Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 8 guías que incluyan este paso.
Inglés
Español
Paso 4
Insert the tip of a spudger between the right speaker and the antenna cable that is routed into the speaker's right side. Run the spudger down along the right side of the speaker to pry the antenna cable from its channel in the right speaker. Run the spudger down along the right side of the speaker to pry the antenna cable from its channel in the right speaker.
  • Insert the tip of a spudger between the right speaker and the antenna cable that is routed into the speaker's right side.
  • Run the spudger down along the right side of the speaker to pry the antenna cable from its channel in the right speaker.
Inserta la punta de un spudger entre el altavoz derecho y el cable de la antena que está dentro del lado derecho del altavoz.
Corre el spudger hacia abajo por todo el lado derecho del altavoz para quitar el cable de la antena de su ranura en el altavoz derecho.
