Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 8 guías que incluyan este paso.
Inglés
Español
Paso 9
You may find it helpful to set the iMac down on its back on the table for the next couple of steps. Use the flat end of a spudger to push the clip on the side of the AC inlet cable connector inward. While holding on the release clip with the spudger, grasp the AC inlet cable, and pull the connector straight out of its socket.
  • You may find it helpful to set the iMac down on its back on the table for the next couple of steps.
  • Use the flat end of a spudger to push the clip on the side of the AC inlet cable connector inward.
  • While holding on the release clip with the spudger, grasp the AC inlet cable, and pull the connector straight out of its socket.
Insertar traducción aquí
