Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 8 guías que incluyan este paso.
Inglés
Español
Paso 5
Pull the power supply slightly up and out from the rear enclosure. Rotate the power supply counterclockwise, lifting the right side up about an inch higher than the left. Rotate the power supply counterclockwise, lifting the right side up about an inch higher than the left.
  • Pull the power supply slightly up and out from the rear enclosure.
  • Rotate the power supply counterclockwise, lifting the right side up about an inch higher than the left.
Insertar traducción aquí
