Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 17 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
  • Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
  • If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
Insertar traducción aquí
