Saltar al contenido principal
Inglés
Español
Paso 12
Remove these phillips screws: To remove all 6, you will need to slide the sliding assembly to get to the center two screws. Now, using a spudger, or  flathead screwdriver, seperate the two halves of the assembly, threading the data cable through it's hole.
  • Remove these phillips screws:
  • To remove all 6, you will need to slide the sliding assembly to get to the center two screws.
  • Now, using a spudger, or flathead screwdriver, seperate the two halves of the assembly, threading the data cable through it's hole.
  • This may take a little force since a mild adhesive is applied around the rim.
Insertar traducción aquí
