Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 6
After removing four Phillips screws securing the inner chassis to the outer case, the guts can be removed in one piece. Controls are routed through two daughterboards; one houses the two push-button elements and the other holds the volume dial. The wireless card is attached to a small interconnect board, converting the four-pin connector found on the logic board into the USB connector used by the wireless card.
  • After removing four Phillips screws securing the inner chassis to the outer case, the guts can be removed in one piece.
  • Controls are routed through two daughterboards; one houses the two push-button elements and the other holds the volume dial.
  • The wireless card is attached to a small interconnect board, converting the four-pin connector found on the logic board into the USB connector used by the wireless card.
  • After a bit too much wiggling, we broke the FM antenna lead where it attaches to the board. Soldering iron to the rescue!
Insertar traducción aquí
