Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 5
The volume knob is simply pressed onto the splined volume control shaft. Use a plastic opening tool to pry evenly around the edge of the volume knob until you can remove it from the chumby.
  • The volume knob is simply pressed onto the splined volume control shaft.
  • Use a plastic opening tool to pry evenly around the edge of the volume knob until you can remove it from the chumby.
  • Volume control commands are sent via a rotary encoder that translates angular degrees of rotation into binary code recognized by the board.
Insertar traducción aquí
