Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 12
Paso 12
Nexus 7 2nd Generation Repairability Score: 7 out of 10 (10 is easiest to repair) The rear case is very easy to open, and requires minimal prying effort with a plastic opening tool to remove... But we cracked it, even though we were quite careful during the opening procedure.
  • Nexus 7 2nd Generation Repairability Score: 7 out of 10 (10 is easiest to repair)
  • The rear case is very easy to open, and requires minimal prying effort with a plastic opening tool to remove... But we cracked it, even though we were quite careful during the opening procedure.
  • All fasteners inside are Phillips screws—no security or proprietary screws here.
  • While the battery enclosure is easy to remove, some patient spudgering will be necessary to peel the battery off the tray.
  • The front glass is adhered to the display frame, meaning you'll need a heat gun to get the LCD out—or replace the whole front panel.
Insertar traducción aquí
