Saltar al contenido principal
Inglés
Español
Paso 7
The outside frame is glued around the edges to the touch screen. Carefully separate the two pieces using the Cutter Blade.
Remove the Outside Frame
  • The outside frame is glued around the edges to the touch screen. Carefully separate the two pieces using the Cutter Blade.
  • If you are changing the digital screen, remove the glue from around the frame completely.
Insertar traducción aquí
