Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 16 guías que incluyen este paso.
Inglés
Español
Paso 22
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red). Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it. Repeat this step with the other adhesive strip and remove it.
  • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
  • Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
  • Repeat this step with the other adhesive strip and remove it.
  • If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
Si es necesario, se puede usar una tarjeta de plástico para cortar las secciones restantes de la tira adhesiva inferior.
-[* icon_note] If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
+[* icon_caution] Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
+[* black] Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
+[* black] Repeat this step with the other adhesive strip and remove it.
+[* icon_note] If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
