Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 16 guías que incluyan este paso.
Inglés
Español
Paso 5
The hard drive SATA cable can't be removed just yet, but will get in the way of removing the logic board. Pull the cable and connector through the right hard drive bracket. Move the cable to the right side of the iMac, out of the way of the exhaust port. Pull the cable and connector through the right hard drive bracket. Move the cable to the right side of the iMac, out of the way of the exhaust port.
  • The hard drive SATA cable can't be removed just yet, but will get in the way of removing the logic board.
  • Pull the cable and connector through the right hard drive bracket. Move the cable to the right side of the iMac, out of the way of the exhaust port.
El cable SATA del disco duro aún no se puede quitar, pero obstaculizará la extracción de la placa lógica.
Tira del cable y el conector a través del soporte derecho del disco duro. Mueve el cable al lado derecho del iMac, fuera del puerto de escape.
