Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 8
Paso 8
Repeat the process of pressing down the spring plate and slightly threading in the screws to install the remaining two heat sink screws. Tighten the screws down a little at a time in the same order that you installed them—in an "X" pattern starting at one corner and then crossing to the opposite corner.
  • Repeat the process of pressing down the spring plate and slightly threading in the screws to install the remaining two heat sink screws.
  • Tighten the screws down a little at a time in the same order that you installed them—in an "X" pattern starting at one corner and then crossing to the opposite corner.
  • Do not over-tighten the screws to avoid damaging the logic board. Just tighten them until they stop against the board.
Insertar traducción aquí
