Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 16 guías que incluyan este paso.
Inglés
Español
Paso 7
Tilt the logic board slightly forward. Lift the logic board straight up and out of the iMac. Be careful not to snag on any of the screw posts attached to the inside of the rear case. Lift the logic board straight up and out of the iMac. Be careful not to snag on any of the screw posts attached to the inside of the rear case.
  • Tilt the logic board slightly forward.
  • Lift the logic board straight up and out of the iMac. Be careful not to snag on any of the screw posts attached to the inside of the rear case.
Inclina la placa lógica ligeramente hacia adelante.
Levanta la placa lógica hacia arriba y hacia afuera del iMac. Ten cuidado de no enganchar en ninguno de los postes de tornillo unidos al interior de la carcasa trasera.
