Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 21 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board. Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board. Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board.
Remove the fan
  • Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board.
Usa la punta de un spudger para desconectar el conector del cable del ventilador de su zócalo en la placa lógica.
