Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 24 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
When working on the power supply, be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges. Disconnect the power supply control cable from the power supply.
Remove the power supply
  • When working on the power supply, be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
  • Disconnect the power supply control cable from the power supply.
Cuando trabajes en la fuente de alimentación, ten mucho cuidado de no tocar los cables del condensador o cualquier junta de soldadura expuesta en la parte posterior de la fuente de alimentación. Maneja solo el tablero por los bordes.
Desconecta el cable de control de la fuente de alimentación de la propia fuente.
+[title] Remove the power supply
[* icon_caution] When working on the power supply, ***be very careful*** not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
[* black] Disconnect the power supply control cable from the power supply.
