Saltar al contenido principal
Inglés
Español
Paso 17
The display enclosure It is actually quite easy to do a DIY screen replacement as there is no glass or adhesive to deal with but there are tabs that snap everything together Removing the 6 screws allows you carefully remove the bezel by carefully undoing the tabs with a flathead screwdriver.
  • The display enclosure
  • It is actually quite easy to do a DIY screen replacement as there is no glass or adhesive to deal with but there are tabs that snap everything together
  • Removing the 6 screws allows you carefully remove the bezel by carefully undoing the tabs with a flathead screwdriver.
  • I recomend using something made from soft plastic to undo the tabs as the plastic bezel and metal back panel damage easily.
  • The hinges simply screw on and off
Insertar traducción aquí
