Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 14
At this point it's a good idea to test your repair, in order to make sure your iMac works properly before you seal it back up. Follow the next three steps to temporarily reconnect the display cables and boot up your iMac prior to pulling the protective film off the adhesive strips. If you've already verified that your iMac is working correctly and are ready to seal it up, skip to Step 16. Gently insert the display data connector into its socket on the logic board. Be sure to press it straight into the socket, and insert it completely.
  • At this point it's a good idea to test your repair, in order to make sure your iMac works properly before you seal it back up. Follow the next three steps to temporarily reconnect the display cables and boot up your iMac prior to pulling the protective film off the adhesive strips.
  • If you've already verified that your iMac is working correctly and are ready to seal it up, skip to Step 16.
  • Gently insert the display data connector into its socket on the logic board. Be sure to press it straight into the socket, and insert it completely.
  • Flip the display data connector lock down onto the socket.
  • Insert the display power connector into its socket on the logic board.
En este punto, es una buena idea probar tu reparación para asegurarte de que tu iMac funcione correctamente antes de volver a sellarla. Sigue los siguientes tres pasos para volver a conectar temporalmente los cables de la pantalla y reiniciar tu iMac antes de retirar la película protectora de las tiras adhesivas.
Si ya has verificado que su iMac está funcionando correctamente y estás listo para sellarlo, ve al Paso 16.
Inserta suavemente el conector de datos de la pantalla en su zócalo en la placa lógica. Asegúrate de presionarlo directamente en el zócalo e insertarlo completamente.
Coloca el bloqueo del conector de datos de la pantalla en el zócalo.
Insert el conector de alimentación de la pantalla en su zócalo en la placa lógica.
