Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 10
The two remaining strips (14 and 15) do not have guide holes and are more difficult to place than the previous ones. Before sticking them down, we recommend first setting them in their respective places on the iMac to get comfortable with their placement. Grasp the red film pull tab on the 14 adhesive strip and pull to remove the backing from the strip. Align the strip on the bottom edge of the rear enclosure, directly to the right of the middle screw on that edge.
  • The two remaining strips (14 and 15) do not have guide holes and are more difficult to place than the previous ones. Before sticking them down, we recommend first setting them in their respective places on the iMac to get comfortable with their placement.
  • Grasp the red film pull tab on the 14 adhesive strip and pull to remove the backing from the strip.
  • Align the strip on the bottom edge of the rear enclosure, directly to the right of the middle screw on that edge.
  • Run your finger along the length of the adhesive strip to ensure it is straight and unwrinkled, pressing down as you go to adhere the strip to the iMac.
Las dos tiras restantes (14 y 15) no tienen orificios de guía y son más difíciles de ubicar que los anteriores. Antes de pegarlas, recomendamos que primera las coloques sobre sus lugares respectivos en la iMac para que te sientas cómodo con la ubicación.
Toma la lengüeta roja de film en la tira adhesiva 14 y tira para remover el respaldo de la tira.
Alinea la tira en el borde inferior del gabinete trasero, directamente a la derecha del tornillo del medio en ese borde.
Desliza tu dedo a lo largo del borde de la tira adhesiva para asegurarte de que esté derecha y desarrugada, presionando hacia abajo al deslizar la tira para adherirla a la iMac.
