Saltar al contenido principal
Inglés
Español
Paso 3
If you are not using a fuse resistor, skip this step. Otherwise, continue. Insert and solder the new fuse resistor to F1 socket.
  • If you are not using a fuse resistor, skip this step. Otherwise, continue.
  • Insert and solder the new fuse resistor to F1 socket.
  • The fuse resistor should sit on the topside of the board and the leads should be exposed on the underside. Orientation of the fuse resistor does not matter
  • The 10M 1/2 watt resistor in the picture is used to depict what a fuse resistor might look like.
Insertar traducción aquí
