Saltar al contenido principal
Inglés
Español
Paso 2
Remove the F1 fuse by using the soldering iron and desoldering wick. The F1 fuse is clearly indicated on the topside of the controller board.
  • Remove the F1 fuse by using the soldering iron and desoldering wick.
  • The F1 fuse is clearly indicated on the topside of the controller board.
  • If the F1 through-hole of the circuit board is not visible, you may clean the it by removing the excess solder by using the soldering iron and desoldering wick.
Insertar traducción aquí
