Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Paso 10
Remove the single 7 mm Phillips screw securing the display data cable retainer to the upper case. This screw may remain captive in the display data cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
  • Remove the single 7 mm Phillips screw securing the display data cable retainer to the upper case.
  • This screw may remain captive in the display data cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
  • Remove the display data cable retainer from the upper case.
Insertar traducción aquí
