Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 15
Paso 15
Lift the logic board enough to gain clearance and use a spudger to pry the microphone  up off the upper case. Slide the logic board away from the port openings and lift the assembly out of the upper case.
  • Lift the logic board enough to gain clearance and use a spudger to pry the microphone up off the upper case.
  • Slide the logic board away from the port openings and lift the assembly out of the upper case.
  • Before reinstalling the logic board, it is easiest to press the microphone down into its housing in the left speaker to keep it in place.
Insertar traducción aquí
