Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 6
Paso 6
Use a spudger to flip up the black plastic tab holding the remaining ribbon cable in place. The black will rotate up 90 degrees, releasing the ribbon cable.
  • Use a spudger to flip up the black plastic tab holding the remaining ribbon cable in place. The black will rotate up 90 degrees, releasing the ribbon cable.
  • The tab is very fragile, so be careful when flipping it up to unlock the cable and down to lock the cable.
  • The plastic tab may be white (instead of black) on some iPhone models.
  • Slide the ribbon cable out of its connector, and remove the display assembly from the iPhone.
Insertar traducción aquí
