Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 8
Using the tip of a spudger to start, peel the adhesive backings off of the strips on the front panel plastic. The adhesive backing is fairly thin, be sure you are only peeling up the backing and not the adhesive itself. The adhesive backing is fairly thin, be sure you are only peeling up the backing and not the adhesive itself.
  • Using the tip of a spudger to start, peel the adhesive backings off of the strips on the front panel plastic.
  • The adhesive backing is fairly thin, be sure you are only peeling up the backing and not the adhesive itself.
Insertar traducción aquí
