Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 9 guías que incluyan este paso.
Inglés
Español
Paso 2
Wedge the pointed end of a spudger beneath the right speaker cable connector. Gently pry the right speaker cable connector up off from its socket on the logic board.
  • Wedge the pointed end of a spudger beneath the right speaker cable connector.
  • Gently pry the right speaker cable connector up off from its socket on the logic board.
  • Be sure you are prying up on the connector, not the socket itself.
Calza el extremo plano de un spudger por debajo del conector de cable del altavoz derecho.
Levanta con cuidado el conector de cable del altavoz derecho de su enchufe en la placa lógica.
Asegúrate de que estés levantando el conector y no el enchufe.
[* black] Wedge the flatpointed end of a spudger beneath the right speaker cable connector.
[* black] Gently pry the right speaker cable connector up off from its socket on the logic board.
[* icon_caution] Be sure you are prying up on the connector, '''not''' the socket itself.
