Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 7 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 15
Paso 15
Lift the logic board enough to gain clearance and use a spudger to pry the microphone  up off the upper case. Slide the logic board away from the port openings and lift the assembly out of the upper case.
  • Lift the logic board enough to gain clearance and use a spudger to pry the microphone up off the upper case.
  • Slide the logic board away from the port openings and lift the assembly out of the upper case.
  • Before reinstalling the logic board, it is easiest to press the microphone down into its housing in the left speaker to keep it in place.
Insertar traducción aquí
