Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 4
This step is only required if you have an anti-glare display. If you have a glossy display, skip this step. Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
  • This step is only required if you have an anti-glare display. If you have a glossy display, skip this step.
  • Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
  • Pull the connector parallel to the face of the logic board, not straight up.
  • Use the flat end of a spudger to pry the Bluetooth antenna cable from its socket on the board.
Insertar traducción aquí
