Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 18 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Lift the top shield up from the right side, minding the upper left corner, which may catch on the metal framework.
  • Lift the top shield up from the right side, minding the upper left corner, which may catch on the metal framework.
  • When reassembling, make sure you pull the antenna cable all the way through the slot in the middle. It is extremely hard to pull it back through after the top shield is screwed back in.
Insertar traducción aquí
