Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Holandés
Paso 4
Disconnect the camera cable connector with the tip of a spudger. Push first on one side of the connector, then on the other side to carefully "walk" it out of its socket.
  • Disconnect the camera cable connector with the tip of a spudger.
  • Push first on one side of the connector, then on the other side to carefully "walk" it out of its socket.
  • Pull the camera cable parallel to the face of the I/O board toward the front edge of the Air to disconnect it from its socket.
  • Do not lift upward on this cable as you disconnect it, as its socket may break off the logic board.
Insertar traducción aquí
