Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Traduciendo paso 15
Paso 15
AirPort Extreme A1521 Repairability Score: 8 out of 10 (10 is easiest to repair). No proprietary fastener funny business over here. The Extreme uses Torx screws throughout the structure to keep its act together.
Final Thoughts
  • AirPort Extreme A1521 Repairability Score: 8 out of 10 (10 is easiest to repair).
  • No proprietary fastener funny business over here. The Extreme uses Torx screws throughout the structure to keep its act together.
  • Disassembly is pretty straightforward, and modular components are used throughout.
  • No glue (except for a small dab used for the status LED) is found inside.
  • The opening procedure requires a bit of prying that may slightly damage the case if the user isn't careful.
  • You'll have to disassemble a good portion of the device in order to clean the fan.
  • Some of the connectors are super-small and can be prone to breaking.
Insertar traducción aquí
