Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 6
Use a flathead screwdriver to release the two clips located on the back half of the drive assembly. The final clip doesn't need to be released; the top half of the drive assembly will slide away from the lower half. Finish removing the top half of the drive assembly from the base.
  • Use a flathead screwdriver to release the two clips located on the back half of the drive assembly.
  • The final clip doesn't need to be released; the top half of the drive assembly will slide away from the lower half.
  • Finish removing the top half of the drive assembly from the base.
  • Be careful not to detach the red wire or the white ribbon cable still attached.
Insertar traducción aquí
