Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 3
Turn the computer right-side up with the front toward you and open the computer lid past 90 degrees. Locate and disconnect the display panel cable. Locate and disconnect the microphone cable.
  • Turn the computer right-side up with the front toward you and open the computer lid past 90 degrees.
  • Locate and disconnect the display panel cable.
  • Locate and disconnect the microphone cable.
  • Locate and disconnect the webcam cable.
  • Locate and disconnect the 3 antenna cables.
  • Unclip the antenna cables from the retaining clips.
  • NOTE There are 2 antenna cables that go from the display assembly through the hole shown and connect to the WWAN (3G) WiFi card if it is installed. In my case they were just threaded into the hole to make things tidy as I didn't have a WWAN card.
Insertar traducción aquí
