Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 2
Remove the blue wire by gently pulling. Disconnect the Brown cable. This is done by gently pulling the black tab away from the white plastic. This will loosen the tension on the brown cable allowing it to gently be slid away from the tab. Shown in the third picture, remove the 4 Phillips #1 screws connecting the circuit board to the optical drive assembly.
  • Remove the blue wire by gently pulling.
  • Disconnect the Brown cable. This is done by gently pulling the black tab away from the white plastic. This will loosen the tension on the brown cable allowing it to gently be slid away from the tab.
  • Shown in the third picture, remove the 4 Phillips #1 screws connecting the circuit board to the optical drive assembly.
  • The fourth screw is located behind the screwdriver in the third picture (highlighted in the orange circle).
Insertar traducción aquí
