Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Traduciendo paso 1
Paso 1
Locate the Bluetooth module cover on the bottom of the laptop Loosen the M2.0×5.0 captive screw and remove the cover by by lifting it straight up The Bluetooth module is connected to the laptop via a small cable with very fine wires - take care not to damage the cable when you pull the module out of the case.
  • Locate the Bluetooth module cover on the bottom of the laptop
  • Loosen the M2.0×5.0 captive screw and remove the cover by by lifting it straight up
  • The Bluetooth module is connected to the laptop via a small cable with very fine wires - take care not to damage the cable when you pull the module out of the case.
  • Gently lift the Bluetooth module up and over the retaining clip. A plastic spudger may be useful.
  • Disconnect the connector being careful not to damage the fine wires on the cable.
Insertar traducción aquí
