Saltar al contenido principal
Inglés
Español
Paso 7
With one half of the ear (1) fully disassembled, we're keen to finally check out the button cell ... ... and we're stopped by two cables clenching the cell tight in their soldered embrace. A soldered battery makes a repair way more complex than we'd like. At this point a battery replacement might be possible, but requires delicate soldering work.
  • With one half of the ear (1) fully disassembled, we're keen to finally check out the button cell ...
  • ... and we're stopped by two cables clenching the cell tight in their soldered embrace.
  • A soldered battery makes a repair way more complex than we'd like. At this point a battery replacement might be possible, but requires delicate soldering work.
  • We leave the battery alone for a moment and remove its plastic brace instead. Embedded within we find the main magnet, which holds the headphone in its charging position inside the case.
  • With nothing left in the opaque white head portion, we'll proceed into the fancy-looking see-through part with the board in it.
  • Expecting the worst, we're surprised to lever open the stem rather quickly. A little bit of heat and prying with an opening tool grants access to the remaining components.
Con la mitad de los ear (1) totalmente desmontada, nos apetece comprobar por fin la pila de botón...
... y somos detenidos por dos cables que aprietan la pila en su abrazo soldado.
Una batería soldada hace que una reparación sea mucho más compleja de lo que nos gustaría. En este punto, una sustitución de la batería podría ser posible, pero requiere un delicado trabajo de soldadura.
Dejamos por un momento la batería y retiramos en su lugar la abrazadera de plástico. Dentro encontramos el imán principal, que mantiene el auricular en su posición de carga dentro de la carcasa.
Esperando lo peor, nos sorprende abrir la varilla con bastante rapidez. Con un poco de calor y haciendo palanca con una herramienta de apertura se accede al resto de los componentes.
