Saltar al contenido principal
Inglés
Español
Paso 6
The in-ear portion of the ear (1) houses the driver assembly, while the battery stays in the outer half of the head. Besides the driver, we find a microphone on this flex cable assembly similar to the one we found in the AirPods Pro. It's positioned to detect in-ear noises for more effective active noise cancellation (and probably helps isolate your voice for clearer calls, too). The driver used in the ear (1) measures 11.6 mm and the voice coil has a diameter of 5.7 mm.
  • The in-ear portion of the ear (1) houses the driver assembly, while the battery stays in the outer half of the head.
  • Besides the driver, we find a microphone on this flex cable assembly similar to the one we found in the AirPods Pro. It's positioned to detect in-ear noises for more effective active noise cancellation (and probably helps isolate your voice for clearer calls, too).
  • The driver used in the ear (1) measures 11.6 mm and the voice coil has a diameter of 5.7 mm.
  • A headphone driver actually consists of three elements: a magnet to create a magnetic field, the voice coil which moves the diaphragm to create the sound you hear when an electric current passes through, and the diaphragm which vibrates to create the sound waves traveling into your ear.
  • The last component of the in-ear portion is the tiny driver grille, quickly pushed aside with the help of a spudger.
La parte intraauricular de los ear (1) alberga el conjunto del driver, mientras que la batería se queda en la mitad exterior de la cabeza.
Además del driver, encontramos un micrófono en este conjunto de cable flexible similar al que encontramos en los AirPods Pro. Está colocado para detectar los ruidos intrauriculares para una cancelación activa del ruido más eficaz (y probablemente también ayuda a aislar la voz para que las llamadas sean más claras).
El driver utilizado en el ear (1) mide 11.6 mm y la bobina de voz tiene un diámetro de 5.7 mm.
El driver de un auricular consta en realidad de tres elementos: un imán para crear un campo magnético, la bobina móvil que mueve el diafragma para crear el sonido que se oye cuando pasa una corriente eléctrica, y el diafragma que vibra para crear las ondas sonoras que viajan hacia el oído.
El último componente de la parte intraauricular es la diminuta rejilla del driver, que se aparta rápidamente con la ayuda de un spudger.
