Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Paso 8
Remove the four 3.4 mm T15 Torx screws from the plastic hard drive carrier (two screws per side). Carefully remove the hard drive from the plastic carrier.  Gentle rocking will see the hard drive come out quite easily. Carefully remove the hard drive from the plastic carrier.  Gentle rocking will see the hard drive come out quite easily.
  • Remove the four 3.4 mm T15 Torx screws from the plastic hard drive carrier (two screws per side).
  • Carefully remove the hard drive from the plastic carrier. Gentle rocking will see the hard drive come out quite easily.
Retire los cuatro tornillos T15 Torx de 3,4 mm del soporte de plástico duro (dos tornillos por lado).
Retire con cuidado el disco duro del soporte de plástico. Sontengalo suave verá el disco duro salir absolutamente fácilmente.
