Saltar al contenido principal
Inglés
Español
Paso 2
Use your compressed air can to blow away loose dust from the motherboard.
  • Use your compressed air can to blow away loose dust from the motherboard.
  • Follow the instructions on your compressed air can. Generally, you will hold the nozzle 3-4 inches from the target, right side up, and only apply short bursts of air.
  • Do not blow compressed air near the fan assembly without holding the fan still, as this can spin the fan blades at high speed and generate a damaging voltage.
  • If you are wearing a grounded anti-static bracelet, you can remove larger chunks of dust by hand.
  • If you have an anti-static brush, you can use it to dust away or loosen dust before blasting it away with the air.
Insertar traducción aquí
