Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Traduciendo paso 7
Paso 7
Remove the following screws securing the fan assembly cover to the rest of the assembly:
  • Remove the following screws securing the fan assembly cover to the rest of the assembly:
  • One 5.0 mm T5 Torx screw.
  • This screw holds the upper case, main fan assembly, and fan assembly together, and so must be removed.
  • 3 Phillips #000 screws.
  • The bottom right screw is just under the I/O board cable, and will be visible after it has been lifted out of the way.
Insertar traducción aquí
