Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Do not remove the gray battery compartment. This image is for illustrative purposes only. Inside the device, the circuit board and antenna frame have three notches for the clips and glue.
Drilling information
  • Do not remove the gray battery compartment. This image is for illustrative purposes only.
  • Inside the device, the circuit board and antenna frame have three notches for the clips and glue.
  • To avoid damaging the internal components, drill through the space next to a clip.
  • This is an image of an AirTag that has already been drilled through at the bottom location.
No quites el compartimento gris de la batería. Esta imagen solo sirve para ilustrar.
Dentro del dispositivo, la placa y la antena tienen tres muescas para los clips y el pegamento.
Para evitar dañar los componentes internos, taladraremos en el espacio cercano a los clips.
Esta imagen es de un AirTag que ya ha sido taladrado por la parte de abajo.
