Saltar al contenido principal
Inglés
Español
Paso 12
No hay imagen
Checking your work - 2
  • If either of these tests fails, you may have to start over, peeling off the previous layer of silicone before applying the new layer, but if the problem is the leak, then you might try tightening the screws a little more. The longer you have left the silicone to cure before reassembly, the less easily damaged it will be by tightening the screws
Insertar traducción aquí
