Saltar al contenido principal
Inglés
Español
Paso 4
To detach the brake, use a 10 mm Allen wrench to remove the bolt from the tire that is attached with the brake. To detach the brake, use a 10 mm Allen wrench to remove the bolt from the tire that is attached with the brake.
  • To detach the brake, use a 10 mm Allen wrench to remove the bolt from the tire that is attached with the brake.
Insertar traducción aquí
