Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 11 guías que incluyan este paso.
Inglés
Español
Paso 3
Remove the following screws securing the camera data cable and right speaker to the upper case: One 9.9 mm partially threaded Phillips screw
  • Remove the following screws securing the camera data cable and right speaker to the upper case:
  • One 9.9 mm partially threaded Phillips screw
  • One 9.6 mm threaded Phillips screw
  • One 4 mm Phillips screw
  • Slide the camera cable bracket out from under the subwoofer and remove it from the computer.
  • The iSight cable has an eyelet through which passes the left-most screw in these pictures.
Insertar traducción aquí
