Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 2
With the panel sufficiently heated, fasten a heavy-duty suction cup near the upper right corner of the display glass. Don't fasten the suction cup on top of the rubber strip around the edge of the display glass. To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
  • With the panel sufficiently heated, fasten a heavy-duty suction cup near the upper right corner of the display glass.
  • Don't fasten the suction cup on top of the rubber strip around the edge of the display glass.
  • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
  • Slowly and gently pull the corner of the display glass up off the display assembly.
  • If only the top edge of the glass lifts up (as seen in the third picture), repeat steps one and two until you can lift up the corner of the panel.
Con el panel suficientemente caliente, fije una ventosa de servicio pesado cerca de la esquina superior derecha del cristal de la pantalla.
No fije la ventosa en la parte superior de la tira de goma alrededor del borde del cristal de la pantalla.
Para fijar las ventosas que vendemos, primero coloque la ventosa con el mango móvil paralelo a la cara del panel de vidrio. Mientras sostiene ligeramente la ventosa contra el cristal, levante el mango móvil hasta que esté paralelo con el otro mango.
Lentamente y con cuidado, tire de la esquina del cristal de la pantalla hacia arriba del conjunto de la pantalla.
Si sólo se eleva el borde superior del cristal (como se ve en la tercera imagen), repita los pasos uno y dos hasta que pueda levantar la esquina del panel.
