Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
In the following steps, you will use a heat gun to soften the adhesive securing the outer black border around the underside of the front glass panel to the display. The area the adhesive is applied  to is shown in red in the second picture. With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
  • In the following steps, you will use a heat gun to soften the adhesive securing the outer black border around the underside of the front glass panel to the display. The area the adhesive is applied to is shown in red in the second picture.
  • With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
  • Always aim the heat gun away from the soft rubber strip around the display glass. Heating the rubber will cause it to melt slightly, turning its finish from matte to glossy. Touching overheated rubber can cause it to permanently deform.
  • Due to the heat applied, it is normal for a layer of condensation to develop on the inside of the glass panel and/or the outside of the LCD. It can be removed with glass cleaner once the glass is separated from the display.
En los siguientes pasos, se utilizará una pistola de calor para suavizar el adhesivo que asegura el borde negro exterior alrededor de la parte inferior del panel de vidrio frontal a la pantalla. El área al que se aplica el adhesivo se muestra en rojo en la segunda imagen.
Con la pistola de aire caliente en posición baja, comience calentando el borde exterior negro cerca de la esquina superior derecha del panel de vidrio.
Siempre apunte la pistola de calor lejos de la tira de goma de alrededor del cristal de vidrio. Calentar el caucho hará que se derrita ligeramente, convirtiendo su acabado de mate a brillante. Si toca el caucho sobrecalentado puede causar que se deforme permanentemente.
Debido al calor aplicado, es normal que se desarrolle una capa de condensación en el interior del panel de vidrio y / o en el exterior de la pantalla LCD. Se puede quitar con un limpiador de vidrio una vez que el cristal se separa de la pantalla.
