Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 3
Using the Phillips #1 or Phillips #00 screwdriver, remove the two 3-mm screws from the card with black and white wires coming off of it. These are not captive panel screws and once loosened will be free to move about the assembly.
  • Using the Phillips #1 or Phillips #00 screwdriver, remove the two 3-mm screws from the card with black and white wires coming off of it.
  • These are not captive panel screws and once loosened will be free to move about the assembly.
  • Be careful not to allow either fastener into the CPU fan and duct (located in the upper left).
  • The card should pop up.
  • Gently remove the card with your fingers.
Insertar traducción aquí
