Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Inglés
Español
Paso 9
Using your hands, remove the small connectors from the small board attached to the bottom of the LCD screen. In order to access the second connector, you will need to remove the protective plastic cover. Make sure to put this back on when installing the next screen. In order to access the second connector, you will need to remove the protective plastic cover. Make sure to put this back on when installing the next screen.
  • Using your hands, remove the small connectors from the small board attached to the bottom of the LCD screen.
  • In order to access the second connector, you will need to remove the protective plastic cover. Make sure to put this back on when installing the next screen.
Insertar traducción aquí
